Hello there. I have had this computer for about 8 years so its pretty old with the parts and all, but it doesnt seem to function well even when it comes to playing games and other things from 2003 for example.
I'm not really good with understanding all this bios stuff, but i try to work around it. I've been having problems with the computer for about 3 years already, and I just found out that my AMD ATHLON XP 3000+ should be at 2.1 ghz processing speed and 200/400 fsb, but it seems that whenever I set these setting the computer just dies. It just shuts off with no warning whatsoever.
I've had it at 133mhz and its a complete waste since I cant play any games with it, its a struggle. I also compose in cubase and it just works crap.
I just tried it with 166mhz fsb and it died a few minutes after. So i'm running it at 133mhz currently.
Here are the specs: (Using CPU-Z for most)
PSU : Dell HP-P2507FW (http://www.atxpowersupplies.com/250-watt-power-supply-FSP250-60ATV-1A.php)
Motherboard: Asus A7n8X-X (Nvidia NFORCE 2400)
CPU: AMD ATHLON XP 3000+ BARTON (10.5 multiplier)
RAM : Slot 1 - Kingston DDR 256mb PC3200 (200mhz)
Slot 2 - Team Group Inc 512mb PC3200 (200mhz)
Slot 3 - Nanya 512 mb PC3200 (200mhz)
Graphics: NVIDIA GEFORCE FX 5600XT 128mb
As far as I've searched google, its supposed to run at 200fsb just fine, but it doesnt even do 166. I figure i've got something set wrong in bios. :s
A few hours ago I managed to run it at 166fsb by messing around with the chipset settings at bios and putting QFAN at full speed.
It went for a while until it died again a few minutes ago.
The settings I recorded for 166fsb that I used were:
FSB - 166mhz
Multiplier: auto (10.5x)
System Performance: Aggressive
SDRAM Active Precharge: 7 (set automatically)
SDRAM RAS to CAS delay: 3 (set automatically)
SDRAM RAS Precharge delay: 3 (set automatically)
SDRAM CAS Latency: 2.5T (set automatically)
Graphics: 128mb
CPU VCORE: auto; 1.65V (didnt touch this)
AGP Frequency: Auto (didnt touch this)
DDR Reference Voltage: 2.6v (didnt touch this)
AGP-VDDQ Voltage: 1.5V (didnt touch this)
and QFan at full speed.
It worked for a bit and then died. I turned it on again a few times and it died each time. Then at one point the clock was reset to January 1st 2002 and I had to fix that. :s
I noticed after I booted again in the hardware monitor in bios
the MB temperature was 27 degrees celsius
the CPU temperature was 66 degrees celsius
dunno if these mean much
Can anyone show me the right bios settings to use to make it work well at 200fsb or even at least 166fsb as it should? :S
Would really appreciate it, cheers!
FSB - 166mhz
Graphics: 128mb
