- Aug 13, 2010
I can't decide if I should go with a newer 2066 motherboard and x series processor which I've been finding deals in the neighborhood of $530 to $600 for a mid range 2066 motherboard and 7800x processor or if I should go with something like a 7700k and equivalent MB for less... but not too much less. My current mb/processor has lasted almost 10years so I'm not concerned with with how much I spend on this... to an extent.. (I have no need for 16 cores) assuming it lasts another 7 to 10 years.
My current rig:
Gigabyte GA-X58A-UD3R
Intel Core i7-930 currently @ 3.8ghz
Mushkin 1TB SSD
16GB Crucial Ballistix Tactical LP ram
Gigabyte Nvdia GTX-970 G1
Thermalright U120eXtreme CPU cooler push/pull
Antex 900 case
EVGA Super Nova 850 G2 80+ PSU
I'll eventually go to a 1080Ti once the prices drop a bit. I want something I can OC. I can add water cooling and upgrade the case no problem. What's the go to setup for OC and gaming for bang for your buck at the higher end level? I will be buying one of the gsync HDR monitors when they come out.
Thanks
My current rig:
Mushkin 1TB SSD
Antex 900 case
Thanks
