- Apr 12, 2016
This is my first time building my own desktop.
After you put together all the parts, how can you immediately test your CPU temp to make sure it doesn't overheat, before you have even installed the OS.
I've read about recommended programs like HWMonitor, but you need to have Windows already installed to use them.
My big concern is that if the thermal paste isn't applied correctly and while I spend 2 hours installing Windows, somehow my CPU overheats and destroys the mobo.
Does anyone here test the temps prior to installing the OS, if so, what do you use/how do you do it?
