- May 29, 2008
- Missouri
Hi all,
I'm having an issue after swapping the CPU on my build. What has happened is that I swapped an i7 2700K for the 3570K that was in my build. After doing so, I booted the pc back up and no video. I pulled and reset the card and memory, cleared the cmos again (I had done it before pulling the 3570K) and tried again with the card in the top PCIe slot. Still nothing. I can get video from the onboard and tried a 8800GTX and a 9800GTX+ and both of those worked. I put the 670 in my wifes PC, it is exactly the same, except the boot hdd and the video card, using a 3570K, and it worked fine. I finally got the 670 to be recognized in the bottom slot but would like it in the top as the airflow off it helps cool the PCH. I didn't reformat or anything, just popped the 2700k in and rebooted after clearing the cmos. I've tried setting slots to Gen 1, 2, 3, and auto and it still isn't recognized.
Here are my specs
ASRock Z77 Extreme4 bios 2.80
i7 2700K
Gigabyte GTX 670 Windforce
OCZ SSD
Corsair 750W
HAF 932
Thanks
Here are my specs
i7 2700K
OCZ SSD
Corsair 750W
HAF 932
Thanks
