- Nov 14, 2002
I'm going to buy a new computer..
With it I have a Antec case, with a TruePower PSU (430W)..
anyway, I want good cooling!
This case has 2 rear, 2 front and 1 side vent..
First of, I want dust filters on all of my fans that are taking in air..
I want to noise-isolate(??) the case also, which will make the degrees come up a bit..
Anyway, I'm planning on buying these 5 vents:
Arctic Cooling 80x25mm TC-1, Heat-reglated (works harder if it's hot or something)
1700/3000 rpm
13/26 dBa
25,1/53,1 airflow (m^3/h)
Any opinions or suggestions for making my case ventilation better?
BTW, Should the side fan be sucking in air or blowing out?
Thanks
1700/3000 rpm
13/26 dBa
Thanks
