- Jul 20, 2002
I'd like to improve the case ventilation for the video card in my Thermaltake Armor Revo VO2000. The PSU is installed in the floor of the case directly underneath the videocard. The case has a filtered vent from the HDD cage that extends all the way to the back of the case. My idea is to cut a hole in the sidecover over the motherboard tray (on the opposite side from where the motherboard is mounted) that has the dimensions of a standard ATX PSU, use zipties to mount the PSU unit there then route the cabling trunk through a grommet also cut in the sidepanel. This will result in the PSU sticking out from the side of the case but it'll allow the videocard to get much cooler air. I'd add fan filters and shrouds to the PSU so it's not sucking in dust.
I've also thought of using this:
https://www.grainger.com/product/HOFFMAN-Fan-Bracket-32FL14
To attach the PSU to the back of the motherboard tray.
Any thoughts?
Any thoughts?
