- Oct 6, 2004
- Philly
I recently bought two 4K monitors with thge hopes of having a nice dual-monitor setup. Each monitor has 1 displayport and 2 HDMI ports. At first I had each monitor connected to the GPU via DP cable, but I would have daily problems with this, such as one monitor not turning on after the computer comes out of hibernation or sleep. Then I tried daisy-chaining the monitors using a DP cable to the GPU, and aan HDMI cable from the first monitor to the 2nd. The 2nd monitor isnt being recognized, and I was wondering if I can daisy-chain with DP and HDMI, or do the cables have to be the same, or do I need an adapter of some sorts? What would be the best way to connect these monitors, and not have daily problems like I had when both were connected to the GPU?
Asus VP28UQG monitors
