- Jun 21, 2002
Ok, I followed the handbook and installed gentoo, then installed x and gnome. So far so good, but I am having some problems.
mounting a ntfs drive:
however using make menuconfig, I recompiled the kernel with ntfs support and it did nothing.
cups:
go into system>administration>printing and I get "the CUPS server could not be contacted."
I have emerged cups.
sound (xine):
running amarok, I get "xine was unable to initialize any audio drivers"
any help would be greatly appreciated. Also I am using either an mx400 or mx500 with USB right now (lost the adapter), but I don't really expect these to work. I have tried various /etc/X11/xorg.conf files in gentoo's documentation.
Code:
justin justin # mount -t ntfs /dev/sda1 /mnt/sda1
mount: unknown filesystem type 'ntfs'
Code:
justin justin # modprobe ntfs
FATAL: Module ntfs not found.
cups:
sound (xine):
