- Oct 12, 2002
- San Diego
Sorry for the newb post, but I'm new to Intel. First here's my list of components:
-IC7-G w/ first BIOS i think
-2.4Ghz P4C Retail
-OCZ EL PC3500 2x256
-Thermaltake Xaser 480W PS
-Sapphire Radeon 9500 Pro
-2 x 80GB WD 8mb
-Audigy 2
-Chieftech Case w/ 6 Fans--case temps around 24C
-SLK947 w/ AS3 and Enermax 92mm Fan--temps around 36c at stock voltage/speed
So anyway, with my older Mushkin pc3200 I can get to around 3ghz with the 3/2 /5/4 ratios. Then I upgraded to Geil Golden Dragon pc3500 to try and run at a higher memory frequency. It did not work AT ALL in my IC7, so I RMA'd it. Now I have some new OCZ PC3500 cas2 (showing cas 2.5 in BIOS, not sure why..), and it wont let me even get close to 3ghz at any ratio. It won't even post unless I lower it down to 230 or less FSB at any ratio and with relaxed timings as well. I even tried upping the vdimm and vcore a bit but that didn't seem to help. I'm getting a bit discouraged that I'm not getting good overclocks like everyone else.
Any suggestions are appreciated.
Thanks
-2.4Ghz P4C Retail
-2 x 80GB WD 8mb
-Audigy 2
Thanks
