ok what I have:
OS = windows 8.1 enterprise 64bit,
CPU = amd fx9590,
CPU COOLER = Cooler Master V8 GTS - High Performance CPU Cooler with Horizontal Vapor Chamber and 8 Heatpipes,
MOTHERBOARD = ASUS SABERTOOTH 990FX R2.0,
RAM = G.SKILL Sniper Gaming Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900),
VIDEO CARD = GIGABYTE GV-N970G1 GAMING-4GD GeForce GTX 970 4GB 256-Bit GDDR5 PCI Express 3.0 SLI Support Video Card,
MAIN DRIVE = OCZ Octane OCT1-25SAT3-256G 2.5" 256GB SATA III 2Xnm Synchronous Mode Multi-Level Cell (MLC) Internal Solid State Drive (SSD),
STORAGE DRIVES (3) = Seagate Constellation ES.3 ST3000NM0033 3 TB 3.5" Internal Hard Drive.
I built this pc for photoshop and lightroom, it should be running very fast but seems to be running slower then I feel it should. In the bios in easy mode I have it set to the highest performance setting of the three they give you. I want to get the most stable and the most performance I can get out of this pc. It is very slow pulling up the storage drives I have them set so they don't sleep so not sure why they are so slow. So any help would be awesome.
CPU = amd fx9590,
