- Sep 10, 2002
- Dallas, Texas
Okay, here's the plan. I want to completely transform my dell latitude cpx pIII 500 into a stylish notetakin, gamin machine.
Moding to be done:
- switch out the fan....the stock one is a piece of crap
- add tempature display between power switch and leds using an old thermometer
- attach an EL wire to the power source, with an on/off switch to light the keyboard from beneath
- possibly add a stylish window to the back of the lcd screen that will be lit by the lcd screen itself
Okay, I know that sounds like quite a bit for a laptop, but I think it is do-able. If anyone thinks that any part of this is impossible, please dissuade me from it now.
I have allready run into some problems in the planning stage. I can't seem to find a good way to wire in an EL wire or thermometer to the laptop's power. I took some quick pics but my dc was actin up, Im not sure if they are clear enough, but I took the liberty of labeling them a bit.
Also, what is missing over by the audio ports? I labeled it what is this?
Moding to be done:
