i would say go for it. I am guessing although they had unlock core option available on earlier version of BIOS but it was not supported/working to unlock cores. MSI says version 2.3 and then after only supports "unlock cores" function. and I heard MSI boards are kinda hard to work on and BIOS very less userfriendly.
But i think its worth to give a try. Update to latest BIOS.
Make sure you thoroughly and again check your MB model number and version on Motherboard itself and update BIOS only downloaded for that Model/version from MSI webside directly.
So, I waited a long while, because I really didn't want to even attempt this process until I had a second reliable computer I could use in the event that something goes wrong.
I'm on my laptop now, because something seems to have gone wrong.
I updated the bios, it took a long while because of the memtests, but after all that, the bios update went through, no problems, and it's now on the latest bios version. I boots and I can get to the bios every time I boot, and get to the select boot device menu as well, however, it no longer detects my c drive I was using, and no longer starts windows because it can't find the drive with windows on it.
While updating the bios, once you run the software it asks you to shut down your computer, take out the power cord from your PSU, reset the CMOS settings via the instructions in the manual, plug it back in, reboot into the BIOS, select Load Optimized Settings, then start it back up.
For resetting the CMOS settings, I had to go to a certain set of pins on my motherboard, and take the provided jumper wire out from the first and second pins, which has it retain the current CMOS settings, then place them on the second and third pins, which has it reset the CMOS settings. Afterwards, return it back to the first and second, which I did.
The only thing I really touched other than those pins while doing this was a cable for my front USB drive, which I unplugged so to get out of the way, then put it back in place where it was before, and now it doesn't detected my main hard drive.
Do you have any idea what could cause a problem like this, or how I could fix it?
On the flip side, I think the updated bios was what it needed for unlocking the extra cores, as I can now easily find the settings to change voltages for individual cores, numbering as many as four cores, so I think now that I have it set to unlock extra cores, once it does start windows, I'll see four cores instead of just two.
We've also recently finally gotten air conditioning in my house, so my room stays at a much cooler temperature, so my computer now idles around 23C and peaks at 29C when it was under full load for the two cores, so after checking the temperatures under full load with four cores, I'm considering overclocking my CPU as well. Any suggestions for that?
Thanks again for all the help, I really appreciate it.
