Okay so I am new to water cooling. I have a swifttech H220x because I planned to improve on my whole water cooling setup. I do not understand the fittings and what size tubing to use whatsoever. I have read the guides and tried to understand it but i keep coming up short.
With that being said, my plan is to buy the Thermaltake Core P5 Open air Wall mount case. I want to watercool the CPU and GPU. I can buy a new pump and reservoir simply because it would make the custom loop look a lot better in my opinion. I definitely want to do hardline tubing, but instead of bending the tubes, I would just use 90 degree fittings wherever needed. My budget is around $200 (not including the waterblock for the GPU) but i can spend more if I needed to.
So in short I need a waterblock for my GPU, fittings, tubing, Pumps, reservoir, radiator, and fans.
I would really like to understand why you guys pick certain parts, because it will definitely help me learn more about water cooling.
Here are my PC specs:
CPU: AMD Fx-9590
MB: Gigabyte 990fx-ud5
GPU: Gigabyte 970 Windforce Gaming
PSU: Corsair 750m
Ram: 16gb Corsair Ballistix
SSD: 250gb Samsung 840, 500gb samsung 840, 1 TB western Digital
CPU: AMD Fx-9590
PSU: Corsair 750m
