After windows automatically downloaded and installed some updated last nite it was slow to boot into windows this morning. i turned it off and when i turned it back on a couple hours later the "starting windows" thing came up and stayed like that.
tried turning off and starting "launch repair (recommended)" but this said loading windows files at the bottom of the screen then nothing black screen
tried recovery disk same thing, tried back up and system image disks same thing
so i tried the original windows install disk but after i enter my country, language and keyboard layout it says starting or preparing install with the loading circle but stays like this and nothing else happens
im on windows 7 64 bit
also it wont boot in safe mode and using last good configuration option got message "boot selection failed because a required device is inaccessible" "status 0xc000000f"
i have an ssd could this be faulty?
