- Dec 1, 2011
Ok im not sure what ive done.
Ive had problems booting for awhile but now after playing around with a few bios settings nothing is now happening.
I was playing with CPU set-up in the bios. Ive attempted to reset the cmos/bios by removing the batt and the jumper settings.
Everything comes on as it would normally but nothing appears on screen ( no signal)
so now my computer is laying there doing nothing.
my motherboard is Asus M4A88TD-V EVO.
any input would be great.
Ive also removed the video card and used onboard and nothing is happening there either. used HDMI/DVI and D-sub and nothing
memory test is ok aswell
Ive also used the spare graphics card and that does not work. Ive removed each memory stick one by one and nothing happens.
any ideas people? Ive read somewhere if i take out the 4pin power connector that powers the cpu , and if the system boots(fans starts spinng) its poss that my VRM on the board is knackered?
Also both graphics card fans go straight upto 100% on start-up and stay there. This has been an ongoing problem but normally sorts itself out after i shut the system and restart again
