- Jan 10, 2006
What do you think? The only item I am still up in the air about is my memory. I've heard alot of good things about OCZ, esp with DFI motherboard but I can't decide on which model. I am going with 2GB unless someone thinks otherwise.
Case: Gigabyte 3D Aurora (Black)
MB: DFI LanParty UT nF4 SLI-DR Expert
CPU: AMD Opteron 175; w/ Zalman 9500 Cooling Fan w/ Heatsink
VC: BFG Geforce 7800 GTX PCI Express
HD: 2 WD Raptor 74GB 10,000 RPM
CD/DVD: Plextor Black IDE Slot Load DVD Burner
LCD: Viewsonic VX922 Black/Silver 19" LCD (2-4ms)
Now the memory.....which do I choose: (I hope the links work)
OCZ Gold Gamer eXtreme Edition 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 433 (PC 3500) Dual Channel Kit System Memory
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory
OCZ 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 600 (PC 4800) Dual Channel Platinum System Memory
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum System Memory
The only other item is OS....I think I will just go with Windows XP Pro 32bit. I thought about 64 bit but not sure I want to deal with all the driver headaches. My primary purpose is gaming and I have not seen enough positive comments on the 64bits impact.
Any other comments on what I have selected are appreciated. Will probably send in my order to Newegg tomorrow. Thanks so much for your help.
