- May 4, 2011
if anyone wants to see it in action, heres a video Linus Sebastian posted about it.
I gotta say that's pretty sweet. I hope he reaches his full production goals.
Why can't you use a off the shelf block with out the IHS? I use to do that all the time with older systems, most you will have to do is remove the lga socket brackets.
The idea is to keep the installation as simple as possible, and the results from the Linus video are encouraging.
The new dies are prone to cracking under pressure so a system like this takes into account clearances so that there is less chance of cracking the die.
Go back to the time of AMD spacers.
This. Direct die cooling used to be the norm and its still the norm with laptop CPUs With the right mounting parts, spacers and not over tightening the heat sink its fine even on thin CPUs.
I don't see how using this block wold be any different. Other then you don't have to remove the LGA bracket on LAG sockets. Witch is not a big deal on most LGA sockets. I could see it cracking the die just like any other block.
I just don't get it, maybe if you want to keep the mobo warranty, but if you deliding a CPU I can't see you caring about the mobo warranty much.
The delid die guard makes a lot more sense to me as you can use what ever heatsink you want.
