Im currently using the CPU above and a motherboard MSI 870 g 45 is it ok to overclock it. If so may anyone here show me the way to do it ? im Newbie to these thing thanks
Right as you enter this forum section is a sticky-ed thread entitled the Ultimate AMD Sticky thread. Tons of How Tos and you get into thread just a hair is the Thuban overclocking section. Once you get into it will give you terminology which is what you need to know to go to bios and adjust by name. Otherwise it just raise FSB, watch temps, add voltage to stabilize while testing with P95 Blend for stability.
Thread Link >>http://www.overclockers.com/forums/showthread.php?t=596023
Thanks you !! here is my INFo
MOBO > MSI 870 G-45 ( MS-7599)
CPU & Cooler > Master Cooler Plus 212
MEMORY > Munskins x4 each 2gb DDR3 DRAM Freq 666.7 Mhz
POWER SUPPLY > Corsair CX 600
VIDEO CARD > GTX 660 ti 2gb
HDDs/Optical drives > 500 GB harddrive
SOUND DEVICE > Onboard
USB > Usb Devices Plugged to Mobo
O/S > Win 7 ultimate
Case > Thermaltake Mid tower/Dont know /Fans Installed 1
