Hi,
I recently built a new multi-purpose rig:
Ryzen 1700
Corsair h100i v2
CM Stryker (Re-used)
G. Skill Flare-X 3200
MSI b350 gaming Pro Carbon
EVGA GTX 1070
I got a stable OC of 3.8 @ 1.36V, with idle cpu temps in 30c and load temps in high 60s. Never went above 69c.
Unfortunately, my Mobo seems to run a bit hot. idles mid to high 30s and under load was going to high 50s...
On previous builds, I was using a hyper 212 and did significantly less OCing. This is my first water-cooled cpu. I read that this can be the case (mobo's running hot) since I had to remove the top 240 MM fan on my case to install the radiator for the CPU.
Is what I'm experiencing a problem? What are some solutions? Do I need to install more fans on this CM Stryker?
Thanks for this help
Ryzen 1700
Corsair h100i v2
EVGA GTX 1070
