So today at work i found this fan. Im wondering if i can connect it to my corsair 1000w PSU and if i can, how can i connect it? it doesnt have a 6 pin or anything on it. its just naked cable as you can see in the pic.
You can't. It's an AC fan, your PSU puts out DC voltage. You will have to connect it to a 220 VAC input, possibly what your wall socket is if you use 220 VAC in your house.
I did. Its working and all but its noisy, and the amount of air that it transfers is crasyy. I currently have it as an exhaust. And the temps inside the case are room temps, i also placed a switch on it so i can turn it on and off easily. thanks
