- Apr 29, 2010
- Central FL
ASUS TUF Detective Server keeps restarting while I game causing my games to minimize and as you can imagine gets annoying. I've searched the net and can't find much information on how to disable it. Just a bunch of information on what it is and since I have no plans on using it I would like to disable it. From what I can tell the only way to remove it is uninstall the whole ASUS suite which I don't want to do because of the fan control and monitoring. The software is up to date and does it multiple times a day. I can end task through task manager and it stays off until I restart but has anyone had any luck disabling it? Thanks.
