- Mar 10, 2001
- Cleveland, TN
Here the scenario...Bought a Dlink-655 to use for me network after using a Netopia 3347-02-1006 for ages. The netopia is my gateway and I assumed it would be as simple to set it to bridge to the new Dlink. Well nothing ever works as easy as you assume it to be.
While the Netopia has the settings to set it to bridge, it doesn't provide a way to physically bridge the device tot he new one. Netopia has only 4 LAN ports, not internet port or whatever. It's also wireless b if im not mistaken.
Anyhow I'm assuming i can get it to work by selecting the other option in the bridge services and that is to run the Bridge/routing, thus keeping the LAN port working and then just jumping a port to the Internets port on the Dlink.
Will the above work or will i experience Issues basically sharing 1 LAN port(from the netopia) for the Internet on the Dlink?
However right now I've gone back to the original state and have my wired devices hooked up to the netopia and using the Dlink wireless since it MUCH faster wireless and the biggest reason i bought the router. (gigabit LAN was the other)
Since only one or the 3 wired PC's have a gigabit lan anyway i figure that'll work for now.
Wireless I have a PC, Wii and a BP that uses the wireless. And any laptops that happen to be in the house from varying family members.
How can i set it up to see the wireless devices and vise versa. Essentially ive got 2 networks and need to get them to talk with each other. Also should I just take the Dlink to my house and look for a new gateway to replace the Netopia.
BTW: I have 2 Networks at 2 locations that i oversee, one at my parents and one at my home. This post regards the setup at my parents, my previous issue with firmware on my Linksys is a issue from my house.
