Thanks for the link. Sadly however, this only serves to confirm what I was worried about. Is "Snap" the only option? If that's true, then you can only have one other app/program on screen at any time... and it will be stuck in a tiny area off to the side (couldn't get snap to open any larger... to say, do a full split screen). Plus, it seems programs have to be compatible with snap to even do that. It appears the only things that run windowed are the system settings and task manager on the desktop screen. I can't believe how hideous this is on a lop top. I can't even run chrome in separate windows... say if I'm shopping and want to compare pics of different items from different websites next to each other. Often I need to have multiple sources of info open onscreen at the same time so I can write up something, or be able to reference things easily. There's got to be a way to do this in win 8, right?
