I did not say anything about accuracy. It is not a constant load, linpack operates in bursts so I can't tell how the NH-U14S does at a constant utilization, he is only going up to 63c maximum.
found this on the noctua website
On some LGA115x and AMD motherboards, the front fan may overhang the first RAM slot, so standard height RAM (up to 32mm) should be chosen when using the first slot.*
it also says that its tailor made for 20xx sockets so it may be to big.
https://noctua.at/en/nh-u14s
Linpack is the software that Intel engineers composed to test their CPU's prior to release. Linpack may operate in bursts, but no other sotware touches it in testing CPU's. My 60+C results reflect a NET temp. Since the basement I test in runs 19-22c, you can see that I run these temps fairly hot. What there is not room for in the review is max temps. They run 92-99c. IOW this testing is at the ragged edge of what heatsinks can do.I did not say anything about accuracy. It is not a constant load, Linpack operates in bursts so I can't tell how the NH-U14S does at a constant utilization, he is only going up to 63c maximum.
The relative performances of the NH-U14S and the NH-D15 are well-delineated in the chart provided in the review.
Bottom line: you will not be able to run hotter software than Linpack. Any software that does not run in Linpack bursts will not heat up a chip as high. I know because I have tried it.
I can remove both RAM modules as they are in Bank A2 and B2. I will have to remove the FAN only. However, it will be tricky as you have like 1-2cm clearance to the block for bank A2. A1 I don't think you can remove or insert anything without dismounting the whole cooler. http://www.overclock.net/forum/5-intel-cpus/1639998-i7-8700k-overclock-results-settings-332.html
LinX is hot. However, have you run Intel linpack? Wow hot lol
