- Jul 5, 2003
- Deep in the Heart of Texas
How hot is too hot?
A few months ago I build a system with an Athlon XP 2000 (1667 MHz). I have 5 fans. Two on the PS, one 80mm blowing in (from the bottom), one 80mm blowing out (top - right next to the CPU fan), and the CPU fan. I use a Thermaltake Volcano 9 to cool the CPU - it has the original 80mm fan on it. (Perhaps the Volcano 9 is overkill but I wanted to make sure the CPU doesn't overheat.)
Since I live in Texas, the room temperature is often 27-28 deg.C (80-82F). The temp inside the box is around 40-42. The CPU is usually 10-12 degrees hotter at around 50-55.
With all those fans, the system is quite loud. The inlet fan and CPU fan can both be adjusted. I have the inlet fan at max to cool the case the best it can. What I've found is that most of the noise comes from the CPU fan. I'd like to turn it down but that will make the CPU temp rise. So, the question is how hot can I run the Athlon without damaging it? Is 60 degrees too hot? What about 65 or 70? I wouldn't want to fry my CPU.
Thanks,
><>Mr. Fri
Thanks,
><>Mr. Fri
