Beware diaz, it may bug you with some apps that ask for a pagefile no matter how many GiBs of RAM you have.
I moved the pagefile to a RAMDisk so I didn't have to worry for it.
WHen it happens I'll deal with it
THanks for heads up though
Could be a few reasons.8GB atm
How does 8gb vs 16 gb differ anyways?
Most likely scenario. Having more RAM allows data to be cached for quicker access. If you look at the Task Manager. Then click on resource Monitor.. then the memory tab. You qwill see that usually more RAM space i used by standby than actual usage.
Another scenario, is that someone is using quad channel.sure they can have 8 gigs in quad (4x 2 gig modules.) Though it is more likely they will run 16 in quad channel. (4x 4 gig modules.)
The last thing that comes to mind. Is that someone has two 8gig kits installed.
I have 9 gigs installed. In conjunction with a SSD. My system is pretty darn speedy. Even though it is an older Intel socket 1366 system.
I hope it makes sense and answers your question.
Well I'll be running dual channel so ideally you would want 2x4GB ram sticks?
What would happen if i want to upgrade from that to say 16gb by adding another 2 sticks of 4GB ram.. does that defeat the purpose of dual channel?
and if i do add more ram, it has to be the same brand and model correct?
16GB
Couldn't pass it up with the 2x4GB kits going for $35...
16 gb for 70 bucks?
RAM is pretty expensive in here - 65$ for 8GB...
So yeah I got 2x4 and 1x2 for 10 in total.
