- Jul 19, 2013
So I'm building a new system with a few old (but clean) parts where I'll be using destilled water (and nothing else) as coolant.
To extent the time between maintenence runs I have installed an in-line UV-sterilizer.
Galvanic corrosion may become an issue, but I'm prepared to take that chance 😬
I have used PrimoChills cleaning program in order to start out in the best possible way.
Rad Clean (rads only), System Reboot and SysPrep.
I have flushed with destilled water after each treatment.
Pump ran for 24 hours per flush.
Now....
With what I had hoped would be the final run (after 2x flush with destilled water) I powered up the UV-sterilizer...
After two hours the water looked like beer... (or urine)... Take your pick...
I would have uploaded a photo, but don't know how (on my phone).
Water had been cristal clear with ZERO color shift (for more than 24 hours) right up to the point where I fired up the sterilizer.
UV light does not turn destilled water into "beer" (unfortunately) 🍻
So I'm guessing that PrimoChills cleaning products does not play well with UV-sterilizers.
I THINK the SysPrep coated the inside of the loop with something in order to prevent galvanic corrosion - But that "something" and UV light is a bad combo.
So, how do I best clean out the system WITHOUT pulling it apart??
Thanks 👍
Now....
Thanks 👍
