- Aug 6, 2015
- Romeoville, IL
Hi Guys,
I have a ThermalTake Core X9 case and I need some help on how to hide some power supply cabling. I separated the case into 2 areas, top and bottom, and the top is starting to look pretty good wire wise. However, the bottom (or basement) area I need some help with. I have a modular power supply (Corsair AX1200) and the wires are just too long for my build. I'm considering scrapping all the wires that came with the power supply for some custom cables (probably even look better and I can make them to match my build colors). I would like some suggestions on how to hide cables in a pretty much open area. One thought I had was to make a "cage" like area right above the power supply where I can stuff the excess cabling. How are you guys dealing with your unruly cables?
William
William
