- May 22, 2011
- USA
what do you mean better radiator fan?
Fans like the AP-53s or eLoop B12s are great radiator fans, for example.
The problem with having one radiator on intake and one on exhaust is that the exhaust radiator will get already heated air. If they're both on the same loop, this is like having a single radiator that's twice as thick. Unless you use fairly powerful fans, you may find that the exhaust radiator has little effect.
The main point of watercooling is to move the heat to where you can get rid of it with a flow of air that has a large cross section. In order to do that, you need as much additional vent as the area of your radiators (or at least the area of your fan blades). Otherwise, your air flow will have reduced cross sectional area, and you'll be missing some of the benefit of cooling with water. You can pile on killer fans to compensate, but that's how high end air works, and if you wanted to go that way, you'd presumably have stuck with air.
I'd start by making sure that each radiator has enough vent. I'm not familiar with that case; can you do that with two in the bottom compartment? Some modification of the floor or side panel may be necessary. Don't worry about intake or exhaust yet, just match up vents and rads. And keep in mind that you need as much area as you have radiator all the way from vent to rad. If your PSU or pump blocks 75%, then the vent only counts for 25%. It's an oversimplification, but treat the narrowest point as the weakest link in a chain and you won't go wrong.
In case I don't make it back this week, intake or exhaust on the lower radiators won't matter all that much, but you'll want them both going the same way. Also you want the air to leave the case through a fan so that it is thrown clear of the intakes for the upper compartment. Hence, if your radiator fans are pulling air into the case, it will help to have fans on the exhaust vents. If you don't need that much fan, put the radiators on exhaust.
If you can get the bottom of your case up off the floor a few inches, that will keep your machine from sucking in fully grown dust bunnies. I don't use filters, but you might want them if your fans are going to be cranked up most of the time and the air is dusty to begin with. An air cleaner in the same room can make a big difference, but the more effective ones are big, move a lot of air, and are not silent. Forget the electrostatic ion marvel mystery machines, they don't do much. If you're not going to mine or fold 24/7, dynamic fan control will do a lot to reduce the amount of dust going into your machine or filters. Less air coming through means less dust.
I don't think that's what I said, but I'm not sure what you're saying, so it's hard to tell. If you mean have one radiator exhaust directly though the other, then no, that's not what I meant.Otter: as I understand you I should put the 480 rad in the side bottom and the second radiator behind it, aka first radiator blow air trough the sidepanle 1 and exhaust tourh the second sidepanel.
I'm saying avoid having one radiator blow hot air through another. Once the air reaches the coolant temp, it can not take any more heat. With quiet fans, the air gets pretty close to the coolant temp in one pass, so the second radiator doesn't do much. With stronger fans, this is less of a problem, but you'll always get more out of the radiators if they draw fresh air.In this case you can't have 2x 480 radiators in the bottom, if you don't mount the PSU soemwhere else, so you end up with in first sidepanel a 480 radiator and the second sidepanel 240 radiator, maby you can fit a 360 radiator if you have a small PSU.
In the pictures, it looked like the upper and lower compartments were completely separate, so I can't see how exhaust from the lower radiators would get up there. But yeah, if there is a large enough path to allow one or both of the lower radiators to blow their exhaust up through the top rad, you'd have the same problem.But, always these buts , whats the diffrence with putting the exhaust at the top or on the second sidepanel? You still blow the same hot air trough the second radiator, if you blow it at the top or via the second sidepanel.
Why would you have all the radiators in the bottom? If you're going to use only two, put one in the bottom and one in the top.With a setup with all the radiators at the bottom i'll get Pump --> 480 Radiator --> 240 Radiator --> GPU --> CPU --> Reservoar --> back to Pump.
Nice rig you got there. Give us a more run down list of what PC components you have and water cooling even though you have more than enough. Some pics of your system when all is said and done would be great as well.
To answer you questions, I have a very similar water cooling setup as you.
The best way to configure your air flow in this mammoth case is as follows:
- Have both bottom radiators and the front as INTAKE (Filtered)
- Have the top radiator as INTAKE (Filtered)
You could have the fans in push or pull but that is up to you. I specifically have mine set as Push.
- Use the rear (Unfiltered) as EXHAUST along with the rear fan.
In this end, this should create some positive pressure which should keep the dust internally at a minimal.
Also, to assist the air flow internally, you'll need cable management done as well.
Hope this helps.
