Hi guys,
I wanted to increase the performance of my ram by oc'ing it.
I haven't oc'd my processor since its not possible with an Intel DG43NB mobo of mine.
My FSB is at 333 MHz now (stock - cannot be changed in my case .So, should I make my DRAM from the current 333 to 400 MHz? Also any info on tweaking h memory timings would be greatly helpful.
My RAM info is :
RAM
Memory slots
Total memory slots 4
Used memory slots 2
Free memory slots 2
Memory
Type DDR2
Size 4096 MBytes
Channels # Dual
DRAM Frequency 332.9 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 37 %
Total Physical 3.00 GB
Available Physical 1.87 GB
Total Virtual 5.99 GB
Available Virtual 4.77 GB
SPD
Number Of SPD Modules 2
Slot #1
Type DDR2
Size 2048 MBytes
Manufacturer Kingston
Max Bandwidth PC2-6400 (400 MHz)
Part Number
Serial Number 48CC1C66
Week/year 10 / 09
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.800 V
JEDEC #2
Frequency 333.3 MHz
CAS# Latency 5.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
Slot #2
Type DDR2
Size 2048 MBytes
Manufacturer OCZ
Part Number OCZ2G8002G
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 18
tRC 24
Voltage 1.800 V
JEDEC #2
Frequency 333.3 MHz
CAS# Latency 4.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 3.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
Thanks.
My RAM info is :
RAM
Memory slots
Used memory slots 2
Free memory slots 2
Memory
Type DDR2
Size 4096 MBytes
Channels # Dual
Physical Memory
Memory Usage 37 %
SPD
Slot #1
Type DDR2
Size 2048 MBytes
Part Number
Week/year 10 / 09
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.800 V
JEDEC #2
Frequency 333.3 MHz
CAS# Latency 5.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
Slot #2
Type DDR2
Size 2048 MBytes
Manufacturer OCZ
SPD Ext. EPP
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 18
tRC 24
Voltage 1.800 V
JEDEC #2
Frequency 333.3 MHz
CAS# Latency 4.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 16
tRC 21
Voltage 1.800 V
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 3.0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1.800 V
Thanks.
