- Jan 10, 2012
Not the ones inside the case, the cables that run across the floor, under, over and around whatever you have your computers on, up the wall to the router, all those your and my bee vacuum up into the vacuum cleaner, your kids try to hang each other with, those cables.
I have 10 computers wired up and ready to go in my office, That's 5 cables per unit, 50 cables total just for the boxes, not including the power cable nor the wires from the network switch to the router.
please help me (and others) reduce the mess from the two that I will be using the most from here on out.
one is an x99 setup with 2 1080s in it and the other is a z97 setup with 2 1060s in it.
they connect to a displayport hub to a dell, 2711 monitor with a sound bar.
the cables are displayport, usb, sound in and mic, Ethernet.
let's start with audio, displayport 1.4 carries audio.
