Sir Jman said:Do you mind posting your other settings? I have the same stepping and am having a lot of trouble reaching 2.8.
the majority of it is in the screenshot. look at the bottom right corner.
Scar said:QUOTE REMOVED by mdcomp
GV2NIX said:These forums are G-rated, I think that was a little out of line.
I have had the same prob with my 146.....Mordith said:CPU Type: Opteron 165 [0551WPMW]
Best Stable OC: 2610MHz
VCore: 1.40
Temps: 21°C/30°C
Core 1 can do 2.8GHz but Core 0 won't even do 2.7 even with 1.55 volts. I did several hours of burn-in on the weak core and I eventually got it to run stable at 2.7 with 1.52 volts. I wanted to see if I could get it stable at 1.50 volts by doing more burn-in but that seems to have made it less stable. After each burn-in session it was able to Prime longer until it went for 9.5 hours without an error. So I figured it was close to being stable at 1.50 volts so I did more burn-in and now it won't even Prime for more than 30 min where as before it Primed for 9.5 hours before it got an error. So I increase the vcore back to 1.52 volts and now its not stable anymore at this vcore because it only Primes for 30 min or less. Makes no sense to me how this could happen.
Sorry, I didn't mean to single you out, I just felt the need to say something. No hard feelings right?Scar said:do a forum search of the word. you'll come up with 3 pages of threads w/ the word mentioned.
Ofcourse Not!!GV2NIX said:Sorry, I didn't mean to single you out, I just felt the need to say something. No hard feelings right?
