I currently have an AMD 5000+ Black Edition CPU, with a Gigabyte GA-MA69G-S3H AM2 690G mobo, MSI 8600GTS vid card, Zalman CPU fan, 2x 1gb G Skill 800mhz DDR2 RAM, Rosewill 550 watt powersupply. So there is my rig running all at stock speeds and clocks. I plan on adding some water,a thermaltake 2U bigwater cooling system. As the title says I am wondering what are the possibilities for overclocking this system. I have read that I can take it all the way to about 3ghz on stock voltage. I am hoping toget to about 3. or higher if this is possible. I must add, I have not done any overclocking any more than with some downloaded software. So if someone can point me into the direction of software or techniques to use and give me some parameters that I can set it too. Thanks in advance. I also am planning on adding a harddrive cooling block, vga cooling block, nothing to do with RAM. Thanks in advance. This is also my first post. Cheers!
Joe
Joe
