1x AMD ATHLON 64 3200+ PROCESSOR S939 2.0GHZ 512KB L2 CACHE RETAIL BOX - $272.22
1x THERMALRIGHT XP-90 S478/754/939 92MM ALUMINUM HEATPIP COOLER *FAN NOT INCLUDED* - $47.42
1x PANAFLO 92MM MEDIUM SPEED COOLING FAN 2450RPM 48CFM 30DBA 3PIN WITH RPM SENSOR - $18.00
2x PANAFLO M1A 120MM COOLING FAN 2100RPM 85.5CFM 35.5DBA 3PIN NO SENSOR - $51.60
1x ZALMAN ZM-MFC1 6 FAN SPEED CONTROLLER 5.25IN W/ 3 PIN EXT. CABLES - $37.74
1x DFI LANPARTY UT NF4 ULTRA-D MOTHERBOARD ATX S939 NFORCE4 ULTRA DDR 2PCI-E16 PCI-E4 PCI-E1 2PCI - $189.99
1x OCZ GOLD VX PC3200 400MHZ DDR 512MB MEMORY CL-2-2-2-8 184PIN - $174.88
1x eVGA E-GEFORCE 6600GT 128M DDR3 PCI-E VGA DVI HD OUT VIDEO CARD - $271.20
1x SEAGATE 7200.7 120GB HARD DRIVE 7200RPM SATA W/NCQ 8MB 8.5MS 3.5IN OEM - $109.93
1x ANTEC SUPER LANBOY CASE ALUMINUM W/ WINDOW NO P/S 3X5.25 6X3.5 - $106.55
1x NEC ND-3520A DVD+RW 16X8X16 DVD-RW 16X6X16 CDRW 48X24X48 DUAL LAYER+R 4X INT IDE BLACK OEM W/SW - $83.43
1x OCZ POWERSTREAM 520 WATT LOW NOISE POWER SUPPLY - $170.43
Total: $1,533.39
How dose the above configuration look?
How much of an overclock should I be able to get out of that?
Any think I should think about changing?
Total: $1,533.39
