- May 8, 2004
Edit - I'm a big dummy
EDIT 09-12-2009 @ 2:12AM - This was an error on my part - The HP Pavilion a1737c does indeed use a standard 24-Pin ATX PSU. See This Post Below for my explanation...
As you were...
Original Post:
So, I'm trying to diagnose/repair my buddy's HP Pavilion a1737c desktop. It currently won't power on or get into POST. The stupid Power Supply (PSU) uses a non-standard 24-pin connector - so I have no way to swap PSU's, or to try this PSU in a different system. I pulled the CMOS battery, still no go. It has Onboard Video - so it's not a faulty video card, and I unplugged all peripheral drives - nothing works...
Here is what I have observed thus far:
The PSU has a green LED on the back. If the PSU's 24-pin connector is plugged into the MoBo, the PSU's green LED is dimly lit (almost can't see it). If I unplug the PSU from the MoBo, the green LED illuminates at full brightness. All voltages test good by manually turning on the PSU with the jumper trick - but this is a "no-load" condition - so the results aren't conclusive - and I don't have any way of "loading" all of the rails to test properly.
Do you think this would point to a faulty PSU that can't provide any current to speak of - causing the green LED to dim (but can supply the correct voltage w/o any current into a multimeter) - OR - that the MoBo is fried and shunting/shorting the PSU?
Thanks for any pointers since my usual component swapping methods won't work with this proprietary HP B.S.
As you were...
Original Post:
