after much reading I have decided on the following for my HTPC.
E5200
GIGABYTE GA-G31M-ES2L
corsair 2*2GB pc2 6400 DDR2 800 ram
Antec earthwatts EA430 430W PSU
ASUS EAH3450 Radeon HD 3450 256MB 64-bit GDDR2 PCI Express with HDMI
Hauppuage HVR-1600 PCI hybrind tuner card
NEC DVD-ROM (just lying around so why buy new)
Thermaltake Wing RS 100 midtower case ( i know its not for HTPC but bought it long time ago for $20 AR. And its shiny black color matches my 32" toshiba LCD)
what about this build. I am planning to OC the cpu to just 3.2GHz although it can handle more but for a non gaming PC thats plenty enouigh I guess.
The only thing so far I have not mentioned is the HD
I just bought the WD 750 GB external HD from staples for $50. I am planning to open it up and use it as internal for my HTPC. I hear it is the green drive.
Here is where I need you guys help.
my options:
1.Partition this HD and install the OS on the smaller partition? If i choose this what is the best way to partition and how to split them (GB wise)
2. Install in a 40GB 7200 RPM seagate IDE HD that I have sitting around and use this 750GB as secondary for media storage.
Can you guys throw me you suggestions.
also. I have windows xp and vista ultimate discs. I am planning to use mediaportal. which OS should I go with? Both are free for me.
thanks much.
E5200
my options:
thanks much.
