- Feb 18, 2007
Hi, I am now having second thoughts about building an HTPC and it is due to news of the coming AMD Trinity and Brazos 2.0 APUs.
As of right now, I have specs picked out for an HTPC that will run me about $360 (Case and everything inside it). I would like to maintain this price range ($350-400).
The parts I've picked out include:
CASE: IN WIN BP655.200BL Black Steel Mini-ITX Desktop Computer Case 200W Power Supply
MOBO: ASRock A75M-ITX FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI Mini ITX AMD Motherboard
APU: AMD A6-3500 Llano 2.1GHz (2.4GHz Max Turbo) Socket FM1 65W Triple-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD ...
SSD: OCZ Agility 3 AGT3-25SAT3-60G 2.5" 60GB SATA III MLC Internal Solid State Drive (SSD)
RAM: G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
DVD: Pioneer CD/DVD Burner Black SATA Model DVR-219BK - OEM
I'm not sure when the new CPUs will arrive, but I don't want to feel like I've made a huge mistake by getting this HTPC now instead of waiting.
Just a couple of questions...
1. Will 200watts be enough for the parts I've picked out? The newegg calculator reports that I need about 210 watts for that system. Should I pick a better PSU? If so, any recommendations for a VERY quiet PSU replacement? (Must be "Standard TFX 12V Power Supply")
2. Should I wait for the new APUs before building this HTPC? I'm trying to hit the $70-90 price point for an APU.
3. I require a mini ITX motherboard. When the new APUs get released, will it take a while for mini ITX motherboards to arrive or will they arrive at the same time?
4. Should I use the stock CPU cooler? If not, do you have any recommendations for a good low profile CPU cooler? (Must have a very quiet fan).
5. Is there anything else I should know about anything? Ideas, suggestions, feedback in general, shoot.
Thanks!
-Neil
Thanks!
-Neil
