- Feb 15, 2003
- Mesa, Arizona
what the heck is this videocard.. it seems like a deal to me, but i havnt ever even heard of it:::
http://www.mwave.com/mwave/skusearch.hmx?&scriteria=aa37270
Description:
The X800 GT series is targeting at Nvidia 6500GT graphics card, to provide better performance with more reasonable price. It is a perfect complement to Microsoft Windows XP Media Center Edition with Dual DVI-I and S-Video output and full-featured multimedia support for analog and digital displays, including HDTV. The X800GT also features an efficient single slot design and ATI's break through image enhancement technology, including 3Dc, SmartShader HD, SmoothVision HD and HyperZ HD, to offer HIgh-Definition gaming power with unparalleled value.
Features:
X800 GT Technology Specifications
8 parallel pixel pipelines
6 parallel vertex processing engines
160 million transistors on 0.13 micron fabrication process
256-bit quad-channel GDDR3 memory interface
PCI Express x16 lane native support
MCE support
SMARTSHADER T HD
Support for Microsoft DirectX 9.0 programmable vertex and pixel shaders in hardware
DirectX 9.0 Vertex Shaders
Vertex programs up to 65,280 instructions with flow control
Single cycle trigonometric operations (SIN & COS)
Direct X 9.0 Extended Pixel Shaders
Up to 1,536 instructions and 16 textures per rendering pass
32 temporary and constant registers
Facing register for two-sided lighting
128-bit, 64-bit & 32-bit per pixel floating point color formats
Multiple Render Target (MRT) support
Complete feature set also supported in OpenGLR via extensions
SMOOTHVISION T HD
2x/4x/6x Anti-Aliasing modes
Sparse multi-sample algorithm with gamma correction, programmable sample patterns, and centroid sampling
Lossless Color Compression (up to 6:1)at all resolutions, including widescreen
HDTV resolutions
Temporal Anti-Aliasing
2x/4x/8x/16x Anisotropic Filtering modes
Up to 128-tap texture filtering
Adaptive algorithm with bilinear (performance) and trilinear (quality) options
3Dc T
High quality 4:1 Normal Map Compression
Works with any two-channel data format
HYPER Z T HD
3-level Hierarchical Z-Buffer with Early Z Test
Lossless Z-Buffer Compression (up to 48:1)
Fast Z-Buffer Clear
Z Cache optimized for real-time shadow rendering
Optimized for performance at high display resolutions, including widescreen HDTV resolutions
VIDEOSHADER T HD
Seamless integration of pixel shaders with video in real time
FULLSTREAM video de-blocking technology for Real, DivX, and WMV9 formats
VIDEOSOAP noise removal filtering for captured video
MPEG1/2/4 decode and encode acceleration
DXVA Support
Hardware Motion Compensation, iDCT, DCT and color space conversion
All-format DTV/HDTV decoding
Adaptive Per-Pixel De-Interlacing and Frame Rate Conversion (temporal filtering)
DISPLAY FEATURES
Dual integrated display controllers
Dual integrated 10 bit per channel 400 MHz DACs
Integrated 165 MHz TMDS transmitter (DVI 1.0 / HDMI compliant and HDCP ready)
Integrated TV Output support up to 1024x768 resolution
Windows Logo Program compliant
YPrPb component output for direct driver of HDTV displays
CATALYST Software Suite
Compatible with ATI's THEATER video decode and capture devices for VIVO configurations
Technical Information:
Memory & Bus Width: 256MB DDR3 256 bit
Core Speed: 475MHz
Memory Speed: 490MHz x2
Output: Dual DVI / HDTV
Interface: PCIEX16
Pixel Pipelines: 8
Direct X Support: 9.0
TV Connector: S-Video
-------------------------------------------------------------------------is this a good deal?
Description:
Features:
MCE support
SMARTSHADER T HD
SMOOTHVISION T HD
HDTV resolutions
3Dc T
HYPER Z T HD
Fast Z-Buffer Clear
VIDEOSHADER T HD
DXVA Support
DISPLAY FEATURES
Core Speed: 475MHz
Interface: PCIEX16
Pixel Pipelines: 8
