[hwbot] 3Dmark01 ranking
Nice one miah :thup:
Here's your mission for 100K on that setup, if you choose to accept it :D
CPU 8x multi (612 x8) 1.6V MCH
Memory 918mhz @ 7-7-7-22 PL10 2.1V VDDR
Cards @ 850/1150 with 100 fan speed & LOD +3, they should do this NP
Test order LH, DL, DH, LL, CH, CL & N or other variation that runs LH first and Nature last.
All the other settings leave on auto.
I seem to have trouble getting this board over about 525 FSB, even with the MCH on water & 1.65V :shrug: But I have very little experience with high FSB. This board does not have a PL setting :( This ram is crap any speed over about 1750MHz, it won't pass memtest86+ at it's rated speed:mad:
[hwbot]110071 - E8600 @ 6100mhz - 2x HD 4850 @ 700/1125[/hwbot]
I was wondering why these looked lower than I remembered having...just realized these are all only my 6.1GHz runs :rolleyes:
[hwbot]110477 - E8600 @ 5843MHz - HD 4870X2 @ 821/1030[/hwbot] FWScore
http://service.futuremark.com/compare?2k1=9425879
Ross, you should be able to hit 900 if you put 1.4-1.45 on the core. Since you're on water you should be ok just for benching.
Thanks Rat, I found your post (I think) about the voltages in the ATI section ;)
EDIT: 1.45Vgpu, didn't touch mem at all: 900/1200 = benchable easy...can probably do 925/1200 after it cools off a bit in here, but 1225 on the mem doesn't seem likely. I just cracked 1K FPS in 01 Nature not even trying, with way less system clocks than I ran for the 98K above :thup: Bring on the cool air!!!!
:shrug: Maybe 99K, but it was no where near cool enough last night to bench with enough CPU clocks as the previous night...we'll see what happens tonight :)
