check sig
work on it.
i have been clocking since '92, still learning.
this hard coding mod with a 9volt battery sounds interesting, although, with the new issues of the AMD chips coming unlocked, not much has to be done unless you have an older board, maybe a vid pin trick for lower multi's, or coding the L's for an X you want, like for my board, if i want 14x, i just code the 2700+ as a 2800+, then i get 14x @auto setting in bios.
although i find your approach interesting, it is almost mute with the newest motherboards now available, at least the x's thing.
owners of slightly older boards will benefit though.
err, links, uh, copy and paste from the address bar on your browser, i use a second browser window, copy, then paste to the other open browser window you are posting with.
skills???. did i read skills????
baldy
