Ok, here we go!
Im using a q8300 quad core on a Asus P5q-e motherboard with 4 gigs of DDR-2 corsair XMS2 ram running at 5-5-18. My video card is the ATI 4870 1 gig GDDR5 video card. Im using a 550 watt powersuppy from corsair (the VX 550W)
I have tried OC'ing this POS chip for a bit then I gave up. I cant get it to run past its stock 2.33 ghz I want to get this chip to 3.2+ ghz I have a Over powered air fan note the idle temp is between 19c-24c It never gets over 30c when I'm running WoW or Farcry 2.
I have tried multiple times to install Vista 64 bit on this rig and it wont work! It also has a tendancy to give me BSODS out the arse! it also likes to randomly reset itself. I will be playing a game or doing something. out of the blue, my screen will go blank then it will reset its self. This ONLY happens when i have a program running in full screen. even if its my internet browser or a simple game of cards.
I have tried installing windows 7 as well. same thing as vista, It will crash during the install a bunch of times then it will stay up long enough to install. it goes to reboot itself (windows says its going to reboot in X seconds) it does that, then it wont fire up. all I get is some missing or corrupt file. /system32/windows/windowstart.exe or something like that. I cant remember what it says exactly. anyways...
WHAT IS WRONG WITH THIS HUNK OF JUNK!??!?!?! p.s. this is the first system I built
love,
from an AMD fan. ^ this is why I like AMD over intel. never had this many problems with AMD
P.s. here are some pics of CPU-Z and the like incase it helps
I also have A program called AI suite and within that. I have AI booster and under the Advanced tab I have CPU<memory< PCI-E
under the CPU tab I have CPU frequency which goes from 200-800 and CPU ratio which has 6.0 or 7.0
Under memory I have DRAM voltage which has Auto and 1.800 to 3.06 It goes up by .02 intervals. I also have Dram Frequency auto 667MHz -1333MHz
love,
