- Apr 20, 2009
Even if I don't overclock, I still spend the first couple of weeks after putting a new pc together monitoring thermals and running afew stress tests.
My new setup is
9700k w/ Noctua nh14
Gigabyte Z390 Aorus pro
16g ddr4 3200mhz
a small hamster on a wheel that doubles for a PSU
Like I said I run temp programs for the first couple of weeks and do a random 10-30minute stress test with prime95 to check how well I seated the heatsink and if it needs to be redone.
After my first couple of benches I was pretty impressed, not going above 55-60c after 20 minutes or so, but today I let it run for 30mins and when I came back I found max temps had hit 82-83 on two of the cores, most stayed around 77-79. The weird thing is these high temps were only hit in spurts and then would go away. For the most part of the test staying around 58-60c.
It seemed to be in conjunction with the wattage on the chip going form 100 wattsduring most of the 20 minutes, then bouncing up to 160 watts.
I watched alittle bit on Gamers Nexus about the chips going far above their spec'ed wattage, but didn't fully understand the explaination of it.
So, what's with these bursts of heat that coincide with the raised wattage? Why does the cpu occasionally pull alot more wattage adding a extra 15-20c to the already 100% cpu temps?
*puts on smart glasses to try and understand explaination*
Opps, I didn't mean to put this in the motherboard section.
My new setup is
16g ddr4 3200mhz
