- Feb 3, 2006
You should be fine.
thorilan said:your buddy isnt the only one laughing at you
your assumtions are completely wrong .
a single 80mm rad would be enough if he wants quiet and a system on par with air cooling. those that talk about heat dump most often have no clue what it means or assume it means MUCH more than it actualy is. even with the strongest pumps we use today for water cooling heat dump from them is usually less than 1/6 of just the processor alone .
im not even going to go into efficiency curves vs dt of smaller rads.
its pretty simple do the math, get some experiance then do some more research .. then give advice
Wwing49 said:Isnt this thread asking for advice? Anyway, I thought that it would be a ***** to OC b/c if you get your processor hotter, it could start artifacting on the GPU. Thanks for the nice comment! I hope you burn out your CPU tomorrow and have to drop a buncha money on a new one.
fuzzba11 said:My BIX2 handles my CPU, GPU, and RAM, you shouldn't have a problem with a single pump.
Wwing49 said:I do wonder if there is any actual performance increase, but they look pimp as all hell! I would get them for just the looks!
ls7corvete said:Dont waste your money, your gonna get burned out on this whole thing soon enough I bet. IMHO, whole things a money pit.
And who said a pa160 beats 4x120??
zeimbo said:there was a review done on it by hardware squad or somewhere. i dont remember exactly where but the pa160 had lower load temps on the proc then a cora 4x120mm rad, i was blown away.
