- Apr 27, 2004
- Central Cali, USA
- Thread Starter
- #21
Thanks for all the great help/comments/suggestions so far guys!!! I really appreciate it!! Keep 'em coming!!
Nitrix said:As for the other component, you made a good list. However, if I were you, I wouldn't get a chipset block. It's restricting the flow and it's only harder to route your tubing. A passive Zalman nb47j would do the job.
SnowRider said:That Zalman NB HS is nice but thx to Intel I can't mount it on my mobo. because of the lack of mounting holes.
One of the "joys" of having an All-In-Wonder 9800 pro is that almost all aftermarket cooling devices don't fit on it because of the tuner box....this includes the Maze 4 GPU block. When I bought the card I payed less money than I would've for the "plain" 9800 pro. At the time I wasn't planning on watercooling or anything so I figured, "I can get a 9800 pro or I can get a 9800 pro with a built in tv tuner and extra software". Well I have to say that it's nice having a TiVo in my computer but I'm finding out the consequences of having that extra box on the card.Arkangyl said:Overall that setup looks pretty good, just a few things to take into consideration;
#1 the PolarFLO GPU block, maybe you could link me to some reviews but the ones I've seen only compare it to high flow / low performance blocks. Right now I'm running the DangerDen maze 4 block and its working very well for me, IMO the design behind it looks a lot better than that of the PolarFLO which, I think is just a chamber for the water.
#2 the CPU block, that block seems to be tied with the Whitewater and RBX for the top dog right now, hell, if I were getting new stuff I'd choose it over my RBX because of looks. Just one thing to consider; DangerDEn will be releasing its new TDX block VERY soon, I'd wait for some reviews and then decide.
Really I'd take a look at the PolarFLO CPU, GPU, NB blocks vs. the Dangerden TDX, Maze 4 GPU and Maze 4 NB blocks...
#3 for a resivouir seriously consider a bayres, it would seem to fit into your case a LOT better than either of the cylenders.
As for the radiator, if you planning to go all internal I'd think a Black Ice Xtreme would be best, I've seen them on the top of Coolermasters without a hitch, I'd think the Heatercore would be a bit on the large side though, and a BIX2 would not fit...
Anyways, good looking settup there, really the difference between PolarFLO and Dangerden is minimal, IMO the main difference would be the VGA / NB blocks and the fact that DD's new TDX has 2x barbs instead of 3x...
So my question is how do these ratings compare to that of a heatercore? Everyone says heatercores are better, but I've never seen actual comparisons between the two.Black Ice Micro II -
* 2-pass Dual 80 mm Radiator specifically developed for PC CPU and GPU watercooling
* Double-row high internal volume design
* New superior durability custom formulation high-gloss acrylic paint finish
* Rated for 570 KCal per hour (2261.91 BTU per hour) or 662.91W
* 160 mm x 73.4mm Double-row copper-finned core consisting of flat tubes for maximum heat conductivity
* High-density copper fin configuration for enhanced heat dissipation
* Built-in enhanced depth plenum chamber for increased performance and noise reduction even when using high-speed 80mm fans.
* Self-tapping dual 80mm fan and case mounting holes for ease of installation
* 9.55 mm OD (3/8 inch) pre-angled inlet/outlet barbed hose connectors (Also available in 6.4 mm OD (1/4 inch) barbed hose connectors)
* Compact 193 x 82 x 46 mm (7.6" x 3" x 1.8") dimensions allows it to fit internally in most cases
Black Ice Xtreme -
# 2-pass Double-row Low Pressure Drop Radiator specifically developed for PC watercooling based on the new high-performance Black Ice Xtreme design.
# More than DOUBLE the performance at the compact Black Ice Prime form factor: rated for 790KCal per hour (3134BTU per hour) or 919Wh.
# 120 mm x 32 mm (4.72 inch x 1.25 inch) Double-row Copper core consisting of flat tubes for maximum heat conductivity.
# High-density louvered copper fin configuration for enhanced heat dissipation.
# Built-in plenum chamber for increased performance and noise reduction.
# Self-tapping and case mounting holes for easy installation of 120mm fans.
# Now with12.5 mm (1/2 inch) pre-angled inlet/outlet barbed hose connectors
Compact 153 x 133 x 45mm (5.9 x 5 x 1.69 inch) dimensions allows it to fit inside most mid-tower cases.
Black Ice Xtreme II -
# 2-pass Double-row Low Pressure Drop Radiator specifically developed for PC Watercooling based on the new high-performance Black Ice Xtreme design.
# Xtreme performance: rated for 1580KCal per hour (6270 BTU per hour) or 1838 Wh*.
Double Row 240 mm (9.44 inch) Copper core consisting of flat tubes for maximum heat conductivity.
# Now with 12.5 mm (1/2 inch) pre-angled inlet/outlet barbed hose connectors.
# Optimal 273.4 x 133 x 45 mm (10.75 x 5.25 x 1.77 inch) dimensions allows it to fit inside most mid-tower cases.
__________End quote_____________
*This is what I'm guessing this radiator's "Wh"(which stands for Watts an hour I'm assuming?) rating is. The site doesn't have it for some reason (even though every other rad has this rating) so I just doubled the Black Ice Xtremes rating. I think this is pretty accurate considering that the BIX II's "KCal per hour" rating is exactly double that of the BIX's.
Oh yeah! You should've seen me when I was taking pics of my setup lol. I think I went a little overboard (I definitely didn't post all the pics I took). After I built this computer which is my first one, I've been addicted to all this stuff haha!! Cheers dude.......I love doing this kind of stuff! I'm glad you like the rad too. I guess it's a little overkill, but hey, tinkering is fun right?
