- Mar 17, 2004
- Helping young Meatballs grow...
About the audio dying, it's because your overclock is affecting your south bridge (which controls your integrated sound). To fix the problem, you can use some thermal adhesive and stick a heatsink on the southbridge and your sound should work better.
About the heat, it's better not to expect the processor to turn itself off if it gets too hot..... by the time it does that, your temps are way to high already. Have you tried downloading Motherboard Monitor 5? It displays the temps in your toolbar so you don't have to open Corecenter to see your temps.
So you have the 3.5 BIOS, you might try doing a search at the MSI forums for that BIOS and see if anyone had an improvement from flashing.
