System specs:
Pentium D 805 Smithfield 2.66 533 mhz. FSB.
ASUS P5B-VM Micro 965G chipset (new addition to this system)
OCZ Gold 4 x 512 MB PC5400 667 mhz.
ATI 1800xt 256 MB.
Seagaate 250 GB SATA HD
X-Infinity 500 watt SLI ready PSU 18/18 12 volt.
Latest BIOS 0613
Default FSB is 533 mhz. on the 805-D. I can not get the system to boot if I raise the FSB over 147 mhz. 20 x 147 = 2.94 GhZ. max CPU speed.
In BIOS, RAM speeds available are AUTO and 533 mhz. until I raise the FSB above 148 mhz. At 148 mhz. and above, BIOS gives me the 667 and 800 mhz. settings in addition to the AUTO and 533. Then and only then.
Note: I had this processor running at 3.5 GHZ with the exact 4 x 512 OCZ RAM DMMS in my ASUS P5LD2-VM 945G board last week. The RAM runs fine at 720 MHZ. Move to this new P5B-VM. With this new board I can get only 580 MHZ. or so out of it? I have bumped the Vcore to 1.4125 volts and the RAM max voltage is 1.95. Could the max 1.95 voltage capable be my problem?
I have tried every possible setting in BIOS including bumping up the PCI clock. BIOS does not offer a 33 1/3 PCI Frequency lock. The only thing I have not tried is removing 2 x 512 RAM. Even with the current 4 x 512 I run dual channel, but at 2T. I have tried 4-4-4-12 and 5-5-5-15. Still no boot over 2.94 GHZ.
Here is an article where the 965G chip performs as well as the 965P chips. I can not seem to get this 805-D to overclock properly on this ASUS P5B-VM board? Could it be because the Pentium D 805 is a 533 mhz. FSB CPU to begin with? The P5B-VM supports Pentium D CPU's as well as C2D and C2Q's. Need some help solving this.
Article regarding 965G chipet performance with C2D:
http://anandtech.com/cpuchipsets/sho...spx?i=2948&p=3
I bought this board to move my e6600 into when I buy a q6600 for my P5B Deluxe 965. So far, the new P5B-VM Micro board I have all the questions about has been somewhat of a dissappointment. TIA.
ATI 1800xt 256 MB.
Latest BIOS 0613
