I need help finding values of EVGA GTX 970 SC (2977 version) components
Karalux
Hello, the situation is that i bought a broken EVGA GTX 970 SC (2977 version) with fixing and using it as a daily driver in mind since im tight on budget. The problem i found in it was a classic gpu core power supply mosfet burn-out which was "fixed" by soldering an inappropriate mosfet in its place, hence the card was dead. So i desoldered the mosfet and the card came back to life. I ordered couple of replacement mosfets and couple controllers or it (to change them too, just in case) but the problem is that at the moment i didnt have a normal hot air soldering station so i used adjustable temperature hot air fan which did not have adjustable speed, hence while soldering it blew away couple of resistors and capacitors which i could not find. I need help identifying those lost components since its the last thing i need to fully fix this card. The components i need to find values of are circled in red (and if possible of those 4 in small green circles nearby, since i cant remember if i havent touched them too). Thank you in advance
