- Dec 10, 2003
I'm aiming to watercool my current computer to hit 4GHz. Usually I wouldn't be asking you guys right away before researching what I should buy, however I'm visiting family in Bosnia and Croatia right now so I figured since I'm in Europe I should see if there's anything I should buy here that I cannot get in Canada.
Was originally going to buy everything from NCIX.ca. I'm in Toronto.
Hardware is as follows:
Antec P182 Case
Antec Quattro 850W PSU
EVGA 8800GTX
P5E3 Deluxe WIFI/AP
2GB OCZ DDR3-1800
Intel Q6600 G0
Currently I can run 450x7 stable but at 450x8 it becomes an issue, with temps reaching high 70s / low 80s with the side panel off. The current cooler is the thermalright 120 eXtreme.
I don't think I'll be watercooling the motherboard as there's too much that I need to buy if I replace the crazy heatpipe solution. Won't be watercooling the GPU either, too much effort and money for what, 20MHz extra on the core?
So I know that I want 1/2" tubing because it looks better that 1/4, and I know that I want to mount the radiator outside the case somehow since the case has watercooling holes. Also, I would prefer to have this as quiet as possible.
Can someone please suggest a high end pump/cpu block/radiator combination? How low can my temps go with the Quad, can I keep it under 50 degrees?
I've heard the 120.3 radiator is among the best, oh and size doesn't matter.
Antec P182 Case
EVGA 8800GTX
P5E3 Deluxe WIFI/AP
2GB OCZ DDR3-1800
Intel Q6600 G0
