- Jun 22, 2002
- Charlotte, NC
Its kind of like free aluminum. Today, I was cutting a hole in the side panel of my lian li. Since it is aluminum, and aluminum is a good conductor for heat... So, since I have about a 1x1 square, couldn't I just cut that into smaller pieces, and use the alumunim as a base, and then use something like the bottom of a can, and make the uber cheap cokecan WB? WB weld that stuff together, and it would work, correct?
