- Jun 22, 2005
like it says i want to buy a 7800gs, wich is better? evga or bfg?
why not xfx? loljeffk said:All brands are good. Just dont buy XFX, trust me
Maviryk said:Actually, all 7800GS' are made at the same factory, then distributed to the different companies, who then test and bin the cards according to their QC and put their own cooler/bios/labeling on them. If you go to the eVga forums there's a 20page thread on problems regarding teh 7800GS.
So it's not just Xfx, but warranty is most important. Xfx probably had bad QC and binned some of their card higher than they could handle and that resulted in a lot of RMAs.
custom90gt said:where do you get this information? As far as I know it works out the same as with all the other vid cards, Nvidia makes the reference design and sells the procs, the companies then build them.
